Re: 350 Utility Steering
Posted by Bill46 on January 19, 2006 at 11:47:11 from (12.36.152.153):
In Reply to: 350 Utility Steering posted by BEWILDERED on January 19, 2006 at 09:03:12:
Paul is right. He has broken the little pin that runs up and down the worm gear to move the large gears in the box.
It's a bear to fix cause all the parts covering the steering assy have to come off. Fuel tank, instrument panel and everything connected.
That is a hardened pin and I do not know if you can still get it.
Good luck....
