Re: My cub wont start...
Posted by El Toro on January 19, 2006 at 14:33:18 from (205.188.116.133):
In Reply to: My cub wont start... posted by Tractorfan on January 19, 2006 at 14:22:29:
You should hold your hand over the throat of the carburetor and see if you have any suction. I would check the compression too. This is where
your manifold vacuum is created by having a good seal on the piston rings and the cylinder wall
not being worn. Squirt some engine oil into each cylinder and then see if the engine will start. The manifold vacuum is what pulls that atomized gas into the combustion chambers. Sounds like the spark is ok. Hal
