Re: M and W turbos/826
Posted by Weldon on January 19, 2006 at 18:06:46 from (151.213.97.154):
In Reply to: M and W turbos/826 posted by Erik in WI on January 19, 2006 at 14:45:48:
If you are wanting to remove the M&W turbo from the engine to return the 826 to original equipment, you will need the cast piece that KB826 described as being bolted between the manifold and muffler.It is described in IH parts book as Exhaust Manifold Elbow (also need the gasket).Probably need a new original air tube between the filter and intake manifold as they usually were cut to install turbo. Remove everything associated with turbo ,plug the oil supply and return holes, install original exhaust elbow,add muffler or straight pipe. You should also return injection pump to original settings if it had been adjusted upward as instructed by turbo installation manual.
