Re: 966 for brushhog
Posted by Erik in WI on January 20, 2006 at 15:47:00 from (65.162.45.60):
In Reply to: 966 for brushhog posted by Rifman on January 20, 2006 at 14:58:56:
The 966 is the best 100 horse tractor I know of. I don't think it is overkill, not if you have hills like we do! Look to see if it has a water filter, which will be on the right side of the motor. That little item will save you lots of trouble. If you know the serial number (right behind the motor, left side) you can find out what year it was built, look for a later model tractor as they made many design changes for the better. I dont consider them a high maintenence machine, just use IH engine oil, and Hytran in the rear end and they will last forever
starting s/n for years
1971 7101
1972 11815
1973 17794
1974 22526
1975 28119
1976 31772 (will have black decals)
