Re: 966 for brushhog
Posted by John A. on January 20, 2006 at 21:11:15 from (65.161.170.65):
In Reply to: 966 for brushhog posted by Rifman on January 20, 2006 at 14:58:56:
Rifman, As Hugh, and Allan have said, I echo once more. Allan and I both presently have one. But we have larger acerage to to give thes ol girls a real work out. A 966 is NOT a tractor to Putter - around with and do light work. Extented running at half throttle will cause the engine to slobber oil from the exhaust and run down the manifold. Doesn't really hurt the engine all that much that I can tell. But a good dose if hard plowing at full throttle will cure it.
A 966 is better suited to a 15 ft batwing shredder than a 8ft 3pt lift model
A 60 horse tractor would be a better choice such as a 460/560. Small enough to trailer, large enough to put a loader on and do chore work. Run a baler, etc,etc. Hope this helps.
Later,
John A.
