Re: 966 for brushhog
Posted by Cliff Neubauer on January 21, 2006 at 05:50:18 from (69.18.16.105):
In Reply to: 966 for brushhog posted by Rifman on January 20, 2006 at 14:58:56:
A 966 will work just fine for what you want to do,it may be a little bigger than you need but that's not going to hurt a bit. We have three 1066's that see mostly light duty work, bush hogging, haying and running augers and it doesn't hurt them a bit. As our farm has grown the 1066's have gone from major field work tractors to planter tractors and now more or less to chore tractors that can be used for field work if we need them. The third 1066 is one we just bought off a neighbor and it will get a very easy life but it was a one owner black stripe model with less than 1,800 original hours and with a good wax job it will look like it just rolled off the assembly line. Our 1066's will use about 3 gph of fuel when mowing hay with a 9' disk mower so your not going to use much more fuel than a smaller tractor.
