Re: oil and spark plugs
Posted by MN Scott on January 22, 2006 at 13:49:51 from (206.9.216.48):
In Reply to: oil and spark plugs posted by glennster on January 22, 2006 at 12:47:51:
For the letter series any good quality oil is fine but if you have an IHC 6 cylinder gas it is critical that you run the low ash oil or you will be burning valves. I run AC plugs in my gassers and I always have good luck with them. I can't tell you the numbers off the top of my head but any parts store should be able to cross referance them for you.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
