Re: oil and spark plugs
Posted by P Backus on January 22, 2006 at 20:31:39 from (69.128.32.83):
In Reply to: Re: oil and spark plugs posted by CNKS on January 22, 2006 at 14:00:00:
hi CNKS,
I"m glad you"ve had good luck with your Champion plugs. I was
turned sour on them when I had two (that I can remember)
brand new plugs go bad on two different occasions in two
different engines. One I can understand, but two.... Then I
started hearing from all the other folks who"ve had troubles, so
it"s more than just rumor.
Now, those same plugs will fire fine in a modern, high tension
ignition system, just not so well in my old stuff. I"ve never had
problems with other brands.
Paul
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
