Re: oil and spark plugs
Posted by CNKS on January 23, 2006 at 16:52:03 from (204.249.178.138):
In Reply to: Re: oil and spark plugs posted by P Backus on January 22, 2006 at 20:31:39:
I really think it's the snowball effect --- regardless, I still don't believe it, could happen with any two plugs, have heard of that in other brands too. The more hype there is about something, the less I believe.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
