Re: Belly pump overhaul
Posted by Janicholson on January 23, 2006 at 05:54:22 from (199.17.6.175):
In Reply to: Belly pump overhaul posted by Rollie In NE,PA on January 23, 2006 at 05:44:55:
If the cylinder on the hitch is set up to be used as a two way device (double acting with two hoses), it could be the piston seals bypassing instead of the B.P. (just a thought) I do not know about kits.
JimN
