Re: super c front seal leaking
Posted by El Toro on January 23, 2006 at 07:47:24 from (64.12.116.65):
In Reply to: super c front seal leaking posted by ny bill on January 22, 2006 at 17:51:37:
Here's a web site for using a hydraulic jack to pull your damper pulley. This was designed for a Cub, but could be modified for the Super C. Hal
PS: Cost about $35 to $50 at your local metal shop. Still need to use a split bearing separator
in front of it. I see Leon told you about the timing gear cover bolts. Hal
PS: Chicago-Rawhide has a speedi-sleeve & seal
if your pulley hub is worn from that old seal.
http://www.ytmag.com/farmall/messages/459316.html
