Re: Air in 560 fuel system
Posted by maplehillfrm,pat on January 23, 2006 at 17:03:10 from (170.215.213.43):
In Reply to: Air in 560 fuel system posted by FarmerFred on January 23, 2006 at 10:16:27:
hello I cant recall where the fuel tank is on the 560,, but I have a 2500 A backhoe , same style as my 454 ,, and that is a bear to get fuel to upon running out, the tank is in teh back behind the seat, I have to face it down hill, the nose that is so it will even get to the fuel hose, sometimes I have to take the fitting off the filter, because t hat is t he first place to get fuel too, I have to pull that hose down a little to get the fuel pass a bend in teh pipe, get it flowing hook it back up loosen the air valve on the top of filter get fuel from there , and continue loosening injectors and whatnot till all air is out, sometimes i can get it to 1 injector and ether it, but that worked only once, (after 2 times you would think I would leaern,, my FIL had a holy fit when he helped me once ,,,)pat
