Re: Again Tempermental H Starting
Posted by MagMan on January 24, 2006 at 06:08:45 from (152.163.100.65):
In Reply to: Again Tempermental H Starting posted by Jarhead on January 24, 2006 at 04:24:35:
Sure there is but usally the condenser goes flat out more than weak. Its under the coil cap but usally you have to take the mag off to replace it unless your handy then you can carefully take it and back it out and take the bake lite washers out with out brakeing them and it will slide out this side . Are you using solid wires to the plugs? Is your rotor in exact time? Do you have a nice blue spark at the plug wires?
JON
