Re: f 20 stuck clutch?
Posted by JeffL-TN on January 25, 2006 at 06:50:19 from (199.82.243.73):
In Reply to: f 20 stuck clutch? posted by mattd on January 24, 2006 at 19:23:31:
My F12 clutch was stuck up pretty good once. I ended up jacking the rear end up and placing it secrurely on jack stands, started the tractor in gear then climbed onto the seat, pressed the clutch pedal in and set both brakes. This works in a snap when all else fails.
