f 20 stuck clutch?
Posted by mattd on January 24, 2006 at 19:23:31 from (207.91.18.48):
started up the f 20 today and pushed the clutch in and it would not disengage. the last time it ran was about 6 months ago and it worked then. i know when my 8n does this the clutch disk gets stuck to the flywhell and usually i can block the clutch so it stays disengaged overnight and usually it will come loose. but i know nothing about the f 20 clutch. but anyway i blocked it up and hopefully it will be loose tommorow. any help will be appreciated
