Re: Paint code
Posted by CNKS on January 25, 2006 at 17:30:01 from (204.249.178.138):
In Reply to: Paint code posted by Dennis McDaniel on January 25, 2006 at 17:21:31:
PPG 71310, DuPont 96766. 71310 may be more orange than you like. If all you are going to use is acrylic enamel, you might consider Case-IH 2150. It is supposed to be an acrylic modified alkyd enamel, probably as good or nearly as good as acrylic enamel. I say "supposed to be" because I bought a quart of it and it just said enamel on the can, I have seen gallon containers had acrylic modified on it. I bought it to get the right color for PPG acrylic urethane -- had to change the toner ratio.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
