Re: Field resistor for generator???
Posted by Janicholson on January 26, 2006 at 12:23:23 from (199.17.6.175):
In Reply to: Field resistor for generator??? posted by DieselDog1 on January 26, 2006 at 10:10:15:
John T has it correct.
Three Ohms would be reasonable. There is going to be wattage that needs to be dumped (less than 20) however if being conservative is good, I would use a resistor that could dissipate 30 watts. Resistors heat up, that is where the power goes. A ready source might include a heater blower resistor from automotive heaters. They come in a package with 2, or three resistors mounted on a small plate. One of these will probably check in close to 3 ohms. (or use a combination of them to achieve about three ohms) Only use mechanical connections, not solder to fasten the resistor wires if you remove them from their assembly.
Good luck,
JimN
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
