Re: Farmall SA 2-pt
Posted by HAS on January 26, 2006 at 16:03:13 from (68.228.161.160):
In Reply to: Re: Farmall SA 2-pt posted by Hugh MacKay on January 26, 2006 at 12:09:32:
Right - We had the 2 way plows and exhaust lift on an A when I was a kid. I have a lot of hours on this machine. The exhaust would lift whichever plow was down, but the exhaust arm would retract when yo let it go. It does not hold the implement up like hydraulics would. The implemnet comes up and the mechanism to the left of the seat behind the shift lever would go over center so it would stay there after the exhaust lift retracts. Then you use the lever to trip whichever plow you desired and let it fall to the ground. There were adjustements for height - and the plow was pulled by a front drawbar coming off the front of the tractor. You adjusted the angle of attack for the plow with the belly lift lever.
