Re: Farmall SA 2-pt
Posted by Hugh MacKay on January 26, 2006 at 12:09:32 from (209.226.106.86):
In Reply to: Farmall SA 2-pt posted by Cue P. on January 26, 2006 at 09:53:25:
Cue P.: Nat has nailed it for you, what you have right behind the seat is a rear rockshaft, designed for lifting rear mounted implements. There were 2 different types, both could raise and lower both sides together and the one with the levers, could have each side raised and lowered individually. The main use for this was the 2 way plow as Nat suggests.
