Re: Torque specs for farmall f-12
Posted by Farmallgray on January 26, 2006 at 17:28:12 from (152.163.100.65):
In Reply to: Torque specs for farmall f-12 posted by DW Miller on January 26, 2006 at 07:13:56:
There aren't any torque specs for them. Or at least the service manuals don't give any. Check with a local bolt supplier for a standard bolt torque chart. The SAE gives standard torque specs for each size of bolt. You may even be able to find the chart on line. Do a search under "bolt torque specs".
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
