Re: WD9 - All of a sudden, Bubbles in the rad.
Posted by Steven@AZ on January 27, 2006 at 06:12:46 from (216.67.213.217):
In Reply to: WD9 - All of a sudden, Bubbles in the rad. posted by grabatire on January 26, 2006 at 21:18:52:
WD-9 has dry sleeves so cavitation-erosion is probably not what is happening.
Blown head gasket or a cracked head.
Had the same thing happen to me with a W-9 gas. Ran good and drove it around several times for around 1/2 or so at a time. Then one day it was running and blew water out the exhaust - had so much rust built up in the head that water couldn't flow around the combustion chambers like it should and it developed a hot spot and cracked. Went through 3 more heads before I found one that wasn't cracked...
