Re: Power unit Horsepower
Posted by El Toro on January 27, 2006 at 09:42:27 from (64.12.116.65):
In Reply to: Power unit Horsepower posted by Ironhorse on January 27, 2006 at 07:52:35:
If that's the same engine that's used in the 240 tractor; I think it would be around 31hp. If the battery cables are still attached at the starter & ground; the ground cable should fit the large positive + terminal on a battery if it's using a positive ground. The negative terminal
on a battery is somewhat smaller than the positive terminal. Hal
