Re: No luck w/300 so far.
Posted by old on January 28, 2006 at 16:42:01 from (207.69.137.34):
In Reply to: No luck w/300 so far. posted by Kelly C on January 28, 2006 at 16:02:17:
Sounds like you need to go back to the bascis. You say you have spark, but does it spark at the right time. Have you checled that the carb gets gas? Do the plugs get wet? Do you have a god vacuum on the intkes of the carb, I.E. if you hold your hand over the intake of the carb does it suck your hand in?? If it does suck your hand in does your hand get wet from gas?? Don't feel bad had the same sort of thing happen to me a few weeks ago. Engine would start and I could get spark, gave up for the night and had a few beers. Went out the next day and just for the heck of it tyied to start it and if fired right up. Never have figured out what happened but it has run since.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
