Re: Farmall 560 oil filter troubles
Posted by Tim Shaw on January 28, 2006 at 19:19:05 from (209.74.230.26):
In Reply to: Farmall 560 oil filter troubles posted by Kevin Kostiuk on January 28, 2006 at 15:13:05:
We had a couple of 460s that got to doing that so we just converted them to a spin on type filter. You can get the conversion kit from a CIH dealer.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
