Re: H bearing noise?
Posted by williamf on January 30, 2006 at 01:48:14 from (66.82.9.59):
In Reply to: H bearing noise? posted by Rick Ron on January 29, 2006 at 16:35:00:
There is a sort of u-joint with rubber bushings/spacers where the drive shaft enters the transmission, more or less directly below the steering wheel, as Tom said. If you rmove the small cover behind the Liftall you will be able to se and lay hands on it.
Wm
