Re: 806D range trans cover removal question
Posted by BarryW on January 30, 2006 at 12:41:32 from (129.162.1.42):
In Reply to: Re: 806D range trans cover removal question posted by jpsepp on January 30, 2006 at 12:15:56:
Thanks for the quick feedback, this place is a goldmine! Sounds like it'll be easier than I was thinking.
But hey, while we're here talking about this part of the tractor I have another question regarding the front hydraulic connections located in the pedestal. There are two on each side of the pedestal and I know the ones on the right side are controlled by the outboard remote lever. Does anyone know if the ones on the other side of the pedestal are on the same circuit or are they on the other remote? In this case, the "other" remote is controlled by the inboard lever, which I know has ports on the rear of the tractor.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
