Farmall A Engine Rebuilding
Posted by DJ in NH on February 01, 2006 at 16:59:06 from (67.22.255.172):
I have a Farmall A that I plan on restoring soon which will require a engine overall. I have a couple of questions which I would appreciate any input from you guys.
1. I have read the add for the Tisco kits. Have any of you bought these kits and have you been satisfied with them ?
2. The kits are availale with stepped pistons. If the engine now has flat pistons can you switch to stepped pistons and if so can you expect any real difference in performance. Does any additional work need to be done to the head / valves to accomodate the stepped pistons.
3. Last question. Have any of you had your engines balanced and did you notice any real improvement. I spoke to a local shop today that has been aroud a long time with a great reputation. The cost is around $ 250 for a 4 cylinder gas engine. The fellow told me don't expect any real gain in H.P. but the engine will definitly run smoother. I relize that a Farmall A isn't exactly a big block racing engine but I plan on keeping this tractor for a long time and really want to do right. Thanks guys for your help.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
