Re: Farmall H leaking
Posted by Windsor on February 01, 2006 at 21:15:12 from (205.188.116.133):
In Reply to: Farmall H leaking posted by Guyzoo on February 01, 2006 at 14:52:34:
If you are talking about replacing the seal that is lurking behind the coupling shown in the above picture, you are dealing with a genuine "bitch" of a job. That thing screws in there. You need the biggest pipe wrench that you can get up in the hole. A big strong boy with a strong back. The tractor needs to be in gear and the wheels chocked. While proped against the right wheel push the pipe wrench with your feet counter clockwise until you hear something break loose. Good luck. The seals are readily available at your local bearing and seal place.
