Farmall H leaking
Posted by Guyzoo on February 01, 2006 at 14:52:34 from (142.166.229.13):
Hi, My H was leaking TDH fluid so I removed the cover plate and I found that there is two shafts that oil is leaking at rear.
I think the upper one is for keeping ground travel and the other for the belly pump. am I right? Anyway, I would like to know if it is hard to change those those seals and How to change them. Can I split it between trans/diff and clutch/belly pump housing without removing the motor??
THANKS FOR YOUR TIME AND REPLY!!
