Re: 826D (D358) Oil Filter Question
Posted by Jim Allen on February 02, 2006 at 12:05:32 from (209.173.160.22):
In Reply to: Re: 826D (D358) Oil Filter Question posted by El Toro on February 02, 2006 at 08:15:10:
Yep, it's the 51768 and I applied oil to the seal. I went back and re-
tightened the filter a couple of times and it's now tighter than it
ought to be but still leaks. Are you saying the groove is normal? If
so, then I may have a bad filter. I'd really hard to tell exactly where
the leak is.
