Re: 826D (D358) Oil Filter Question
Posted by El Toro on February 02, 2006 at 08:15:10 from (205.188.116.133):
In Reply to: 826D (D358) Oil Filter Question posted by Jim Allen on February 02, 2006 at 07:02:09:
If that's a Wix filter 51768 the gasket surface on the filter should seal the filter from leaking.
You should clean the surface where the filter is installed and apply a light coating of oil to the
gasket on the filter. Have you tried to tighten the filter? You usually do not have a problem with a full flow filter leaking. Make sure the old gasket from old filter isn't sticking to the surface of the filter housing. Hal
