Re: O/T Chevy intake leak !!!!
Posted by BillyinStoughton on February 02, 2006 at 14:04:07 from (208.50.85.56):
In Reply to: O/T Chevy intake leak !!!! posted by Paul Shuler on February 02, 2006 at 13:48:17:
While I guess a Chevy isn't a Farmall...I can't even count the number of SBC manifolds (both cast iron and aluminum) I've installed since my high school years. What I have done in the past is use the manifold end gaskets, but put a coat of quality RTV (Fel-Pro gray) to the underside of the gasket, install the gasket and allow it to "tack" into place. Now before setting the manifold, apply a good quantity of the same RTV to the top of that same gasket, and also into the corners where the end gasket meets the manifold gasket...give that a couple of minutes to set up and then drop that manifold on (being careful not to slide the manifold on any of the gasket surfaces). This has always worked for me regardless of application, whether it be the 210HP farm truck or the 538 HP mini-rod. I do find one interesting statement though...you say your are "tired of stepping in antifreeze". These end gaskets are only in place to keep the oil from the lifter valley from leaking out from under the manifold. If you have water coming from under that particular gasket, you have more problems than you may know. If indeed it is antifreeze you are stepping in, it may pay to do a little bit more investigation into the origin of the leak. A bad manifold lip gasket (either front or rear) will only lead to an oil leak.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
