Re: 300 crank-rod journal /any one seen this ?
Posted by Ron in Nebr on February 02, 2006 at 18:13:53 from (12.192.38.156):
In Reply to: 300 crank-rod journal /any one seen this ? posted by RICK/OASIS IDAHO on February 02, 2006 at 13:57:09:
If you really do get lucky and the rod journal on the crank mics ok AND the inside of the big end of the rod checks out too(do check both) you might have come out pretty good.
But, it might be wise to find out for sure why that happened, especially if all the other bearings are good(I"d check a couple of the others while you have the pan off). I"m not familiar with the oiling system on those engines, but if the crank has drilled oil passages to lubricate the rod bearings like cranks in other engines, you might have something plugging up the oil passage to that journal. The plugged oil passage would be the problem, the wiped out bearing is just a symptom. Better to cure the problem than the sypmtom, or else you"ll get alot of practice changing bearings, and sooner or later it WILL take out the crank and rod.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
