Re: Anybody with a 340 utility?
Posted by DC-TX on February 03, 2006 at 10:33:36 from (207.69.139.11):
In Reply to: Anybody with a 340 utility? posted by PaulW_NJ on February 02, 2006 at 17:40:57:
Paul: I will try to help you out here. I have a couple of 340U's and have done this too many times. I think from your comments you are thinking correctly about the process.
-The front of the spring does attach to the crescent shaped piece close to the bottom of the throttle rod.
-The bracket you refer does attach to the 3/4 bolt on the steering housing and it does point directly to the back of the tractor.
-The rear of the spring attaches to this bracket.
-It is very difficult to stretch the spring from the rear and secure it to the crescent shaped piece on the throttle.
This requires patience and maybe some choice words due to the tightness of the working area.
Hope this is a bit clearer than mud. Email me if you like. There are other ways to do this but it requires some parts dissembly.
Good luck-DC
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
