Re: Carp - antifreeze in oil showed up again
Posted by TDK on February 03, 2006 at 21:34:26 from (64.12.116.65):
In Reply to: Carp - antifreeze in oil showed up again posted by Farmall Frank on February 03, 2006 at 13:34:36:
You could also apply pressure to each cylinder one at a time. Find or make a fitting to screw into spark plug hole and hook air compressor to it. With radiator cap removed, watch for bubbles. This will tell you if it is leaking from one of the cylinders.
