Carp - antifreeze in oil showed up again
Posted by Farmall Frank on February 03, 2006 at 13:34:36 from (69.76.145.131):
(Carp is a non-cuss word.)
Thought I had it taken care of -- guess not. Torqued the head properly, then thought I saw one drop of antifreeze in oil.
Got some Bar's head gasket stuff, spent the whole 2 days following the directions, cranked her up, and for the first time, decided to look in the radiator for bubbles -- about one bubble per 10 seconds. Guess the problem I thought was gone is still there.
Might as well get busy. I got to take the head off, have her checked out, get new gaskets, and try again.
I have spent a lot of time and money on this machine, so decided to give her an engagement ring. Might as well -- feel like I am getting all of the other benefits.
