Re: CRACKED A SLEEVE!!! NEED HELP PLEASE!!!
Posted by Keith-OR on February 04, 2006 at 21:59:48 from (207.200.116.5):
In Reply to: CRACKED A SLEEVE!!! NEED HELP PLEASE!!! posted by Booe on February 04, 2006 at 18:55:04:
Booe, if you have access to dry ice, find a piece of 1 inch thick styro foam, cut 2 circles a bit large than your sleeves. Put one in the bottom use clear silicone to hold it in, fill your sleeve with dry ice, put the other piece in the top of the sleeve, to keep dry ice in as you install your sleeve. The problem with your method is that the block has a larger mass than your sleeve,which in a very short time the sleeve bought to the same temp as your block. With sleeve filled with dry ice it will maintain the cold temp to allow you to install without too much hammering. I've had sleeves just slide in using this method. Remember the styro foam circle need large enough so you have to force them into your sleeves. HTH Keith & Shawn
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
