Re: Carp - antifreeze in oil showed up again
Posted by Brownie 45 on February 05, 2006 at 11:06:16 from (207.177.82.97):
In Reply to: Carp - antifreeze in oil showed up again posted by Farmall Frank on February 03, 2006 at 13:34:36:
The mechanic where we take a lot of our work, routinely adds a tube of Aluma-seal [or Silver-seal] to every engine which he does head/ valve work on. He maintains that any small areas which didn't get coated with gasket maker would be covered. These two products don't clog passages in radiators & engines which are over 1/8". These diesels were prone to the head-crack thing. Hope you come out all right on it.
