!aGary-1066 Aux. Control valve
Posted by Michael Sheik on February 06, 2006 at 04:48:12 from (199.153.205.246):
If you are referring to the backup washer behind the oring and plug on the unlatching piston, that was replaced with new one. I also put new plug in and oring. I thought about it last night and the only thing I can think of is that maybe the centering spring has lost some of its tension and is not putting enough pressure on oring and retainer in back side of valve body. The unlatching piston did not show any nicks, grooves, etc. Anyway, I think I will call IH mechanic that I know this morning and may end up getting another set of orings and doing it one more time. Shouldn't take but 30 minutes by now! If it doesn't stay this time, I haven't a clue.
