Re: Milky rearend oil
Posted by Big Don on February 06, 2006 at 09:46:37 from (69.192.245.85):
In Reply to: Milky rearend oil posted by oleduke on February 05, 2006 at 12:43:07:
A very common problem on the British rear end assemblies used in the 424 is water leaking past the draft control rod that mounts vertically ahead of the top link pivot. There is a seal around that rod but as the rod gets rusty, the seal wears out and rain water or melting snow can leak in and it goes directly to the transmssion/rear end oil, not the hydraulic oil. The simple solution we have come up over the years is to make a rubber flap from an old tube about 8" square and bolt it to the top of the hyd. housing and laying backwards over the top link pivot unit. That keeps the water out and solves the problem. Change the oil as suggested by the the other posts and you should be good to go.
Don
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
