Re: 656 Ring gear , can it be flipped?
Posted by K.B.-826 on February 06, 2006 at 16:10:30 from (68.115.111.89):
In Reply to: 656 Ring gear , can it be flipped? posted by Yellott Canby on February 06, 2006 at 12:23:55:
Probably not. The teeth should be beveled on the side that faces the starter. Also, removing a ring gear can strech it just enough to cause it to eventually slip and spin on the flywheel if it is reused.
