Re: Still need help, M still wont start!
Posted by old on February 07, 2006 at 08:17:21 from (207.69.137.203):
In Reply to: Still need help, M still wont start! posted by Granger on February 07, 2006 at 07:39:14:
Well if you have a good spark from the ciol wire that menas the points are working right. You have gas to the carb so its probably good. But and heres one thing that you and others always over look. You probably have a bad cap or rotor. I have one tractor that will run real good and then just or of the blue die. Every time it does that its the rotor and some times the cap. I'd replace the cap and rotor and see what happens, I'll almost bet one of them has gone south on you
