Still need help, M still wont start!
Posted by Granger on February 07, 2006 at 07:39:14 from (199.253.130.17):
From my original post I have done several things to figure out the problem. I have proper gas flow to the carburator. I have proper gas flow when I open the drain plug on the carburator. I think I have eliminated the coil as a problem, since I have a spark (when coil wire is pulled off cap & put close to metal & turn engine over). What else should I try first before I get into the carburator?
As a reminder, the tractor was running fine until the other day when it just all of a sudden quit. I have been trying to start it, but it will not crank over. I did notice that gas starts to leak out of the choke lever on the carb now when I attempt to start. Any other suggestions will be greatly appreciated!
