Re: Wrong fuel pump, 400D??
Posted by Dave Slater on February 07, 2006 at 14:59:17 from (152.163.100.65):
In Reply to: Wrong fuel pump, 400D?? posted by Farmall Frank on February 07, 2006 at 13:16:25:
Thats type B pump, if your engine # is high enough it may be original.If not original IH sold pump # 270000 R91 to replace the original pump.
Lot of 400 have been changed.Your B pump should have a drain tube on bottom.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
