Re: questions on 706d t/a
Posted by the tractor vet on February 08, 2006 at 18:15:21 from (4.124.84.52):
In Reply to: Re: questions on 706d t/a posted by LD in PEI on February 08, 2006 at 17:44:27:
When ya got it tore down to the running gears of a KADDYDID ya do it all at one time a complete T/A ASSY . new clutch pressure plate throwout bearing pilot bearing go thru the MCV with all new gskts. and O/Rings and a spring kit also reface the flywheel and setting of the end play on the T/A assy. and check the splines on the PTO input if they are half gone replace it also as it will fail way before you should ever have to split the tractor again. So from what you have told me YEP NOWS THE TIME TO FIX IT.
