Re: Using Ethanol in an M distillate
Posted by F-Dean on February 09, 2006 at 06:32:45 from (64.30.178.13):
In Reply to: Using Ethanol in an M distillate posted by fisherman on February 08, 2006 at 12:47:29:
I have found two problems with Gasahol (Gasolene with 10% ethanol): (1) The ethanol will clean your tank and fuel lines so clean your filters often when you first use it. (2) Over winter, the ethanol will evaporate leaving the weak gas behind. This can cause problems when you go to start them in the spring.
