Re: Using Ethanol in an M distillate
Posted by 26Red on February 09, 2006 at 08:22:36 from (170.92.100.2):
In Reply to: Using Ethanol in an M distillate posted by fisherman on February 08, 2006 at 12:47:29:
I have found that you can run a mix of 50% E85 and regular gasoline with no problems. If you want to run straight E-85 in your tractor you will havae to adjust the carb to give it more fuel. If you want to run it in your carburated pickup, you can buy an alcohol carb from Holley. If you have a fuel injected vehicle no designed for E-85, you can run the 50% mix or buy this Flextube gadget to run 100% E-85.
I have run the last 50K with a 50% mix of E85 with no problems.
You can now get E-85 compatible trucks from GM- 5.3 v-8, Ford 5.4L v-8, Nissan 5.6? , and some Dodge 4.7L v-8 models.
