Re: early/late D282 differences
Posted by P Backus on February 09, 2006 at 11:01:15 from (69.128.32.229):
In Reply to: Re: early/late D282 differences posted by JakeF on February 08, 2006 at 08:59:59:
Hi Jake, how is it?
So are the heavy press engines better at not cracking sleeves?
It"s a pretty bad track record to have 3 for 3 engines with
cracked sleeves. Of course you are probably in the engines
because they had troubles anyway.
So how does that 660 do at pulls? Must sound nice.
The Magnum is all tucked in the shed- won"t know if I got the
problem fixed or not "til spring work starts. Have you ever
messed with the brakes on those? I can"t seem to get the
problem fixed. Next thing I"m going to do is adjust the pedal
height and spool height in the master cylinder.
Paul
