Re: Farmall H Hydraulic Fluid
Posted by Nat 2 on February 09, 2006 at 13:22:16 from (64.80.108.53):
In Reply to: Farmall H Hydraulic Fluid posted by Ed Harper on February 09, 2006 at 10:49:29:
The elbows are the pressure taps from the control valve. No fluid will seep out of them unless the valve is really buggered.
Just fill it until it is full. You can't hurt it by "overfilling," and in fact, some of the early loaders actually fed extra fluid straight into the fill pipe as you raised them, because the belly pump could not hold enough fluid on its own for the giant one-way cylinders.
