Re: Just a off topic Hypothetical
Posted by Steven@AZ I was off... on February 09, 2006 at 14:39:50 from (216.67.213.217):
In Reply to: Re: Just a off topic Hypothetical posted by Steven@AZ on February 09, 2006 at 07:31:10:
I was off on my number for a starter home. There is one right across the street from where I work in an OK neighborhood (some nicer houses, but mostly run-down trailers) that is currently being built. Looks to be around 1400 square feet with a 2 stall garage on a small lot... Called up the realtor, $239,900. I hung up on her... $20k is nothing these days.
